Display panel adjustment setting not showing. - c454e
  • Nelo
    Hi Everyone
    Got this bizhub c454e, I was gping to adjust the touch panel but the panel adjustment setting in the Accessibility section is not showing. I upgraded firmware but still the same. Is there a software switch I need to turn on for the setting to display. Any ideas that may help solve my issue.
    Thanks.
    Nelo
  • RRodgers
    • Jun 2009
    • 1947
    Re: Display panel adjustment setting not showing. - c454e
    Originally posted by Nelo
    Hi Everyone
    Thanks.
    Nelo
    Same machine that won't do gradation adjustment?!?! I forgot the name of the setting but I'd be willing to bet it has something to do with the admin security level.
    • kingarthur
      • 1369
      i know that the touch panel adj has been removed from the set up with the latest firmware, got a feeling the gradation is no longer necessary on set up too...
      • jotunn
        • 618
        Check if software switch 25 is set properly for your firmware.
        • Nelo
          Thanks guys will have a try on the security settings and software switch.
            • 23009
            Do you have a key counter connected to the machine? A whole lot of functions disappear when you enable the key counter. =^..^=
            • rrrohan
              • Sep 2011
              • 1977
              Do a firmware update but hold down reset button when you turn power on same as you would for a trouble reset. This will open a automatic touch panel calibration. Once this is done it will continue on to the firmware update
              • mendelieves
                • Oct 2015
                • 2
                something new? switch 25 no work....
