c351 bottom fuser roller stripped
  • starfish05
    • Jul 2025
    hello! - new here, but i've read a few helpful tips from people on here, so i thought i'd ask here
    today a STUPID customer gave me some paper to copy onto, but it had a sheet of plastic hidden in the ream - as a result, the plastic melted and has stripped the bottom roller - rubber all over the place!
    any ideas where i can purchase a new roller? - are they difficult to fit?
    many thanks in advance
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    The fuser is a field replaceable unit. You can not order the roller. You will have to replace the whole unit
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • mtech
      • Mar 2007
      • 307
      That was a costly mistake. You do have to replace the fuser and man they are not cheap!
      • ni311
        • May 2008
        • 658
        4049 521 - FUSING UNIT 100V - JAPAN
        4049 522 - FUSING UNIT 220-240V - EUROPE
        4049 523 - FUSING UNIT 120-127V - USA, CANADA
        It's around $500, I googled it and I found this:
        Fusing Units Bizhub C351 C450 Fusing Unit 4049-523
        Konica Minolta Error Codes - Explanations and Solutions
        • starfish05
          many thanks for the replies!
          luckily, a friend of a friend has a spare fuser unit lying around, which he's willing to bung in the machine, for some *beer* money.
          still FURIOUS with the customer mind!
          • wagon
            Village Idiot
            • Dec 2006
            • 654
            You can replace the pressure roller if you get one out of another (wrecked) fuser unit - say, one with a stuffed upper roller. They are a pain to pull apart and reassemble, though. Don't chuck the old one away - you may be able to use parts out of it later.
            If you are hitting your head up against a wall it always feels better when you stop.
