REPLENISH TONER ERROR for yellow
  • Dana
    • Sep 2025
    [Dead] REPLENISH TONER ERROR for yellow
    I have Bizhub C652,the machine keep displaying REPLENISH TONER ERROR for yellow toner cartridge, and the message does not disappear even after replacing with different four New and refilled toner cartridges, what could be the problem and how could it be fixed? someone told i have to update its firmware, can someone send C652 firmware to me? pleaseeee..
    Thanks,
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: REPLENISH TONER ERROR for yellow
    Thanks,
    [ATTACH=CONFIG]26554[/ATTACH]
    have you checked the basics. Is the sensor in the toner hopper working? Is the toner hopper motor working? Is the toner add motor working?
    who told you firmware would fix it? I have neaver heard of firmware fixing this issue....
    The gene pool could use a little chlorine.
    • Dana
      Yes they work. I dont know I just read it from one site. Ok so I dont care about firmware, but what else? how can I fix the issue? can you tell me some steps? Thank you...
      • Deepak Grover
        • Apr 2023
        • 1
        To Fixed this Error plz change both chips (Toner + Drum Unit) ...
        • allan
          RTFM!!
          • 5462
          Could also be bent copper pins that contacts onto the chips. It could help to rechip the IU...
          Had it where it comes right after a system error clear.
          Whatever
          • 40yearsplus
            • May 2020
            • 113
            Think you may need to call a KM service company. This sites for Techs or those who donate to the site. Its not an easy troubleshooting process if you are sure you put the proper toner in.
            • femaster
              • May 2011
              • 1527
              Personally, I'm hoping they no longer have the machine as the original post was from back in 2014. If it hasn't been resolved by now, it's certainly been replaced.
