BizHub C360
  • copyman
    Owner / Technician
    • Sep 2005
    • 4736
    BizHub C360
    Making a grinding / clicking gear noise. It was
    intermittent at first but consistent now.Sounds
    like the middle of machine. I removed the transfer
    belt, vacuumed out cleaning unit on belt.
    Everything looks good. Put belt back into machine
    and ran 50 copies, no noise. Left, got a call 10
    mins later the noise is back.
    Also customer claims it will make the same noise
    briefly while sitting idle.
    Any known issues with this model making noise?
    By the way only 42k clicks on the meter.
    Thanks in advance
  • Phrag
    • Oct 2012
    • 417
    Re: BizHub C360
    It's an agressive sort of rattling grind. Like plastic teeth clicking harshly?
    Have you vacuumed out the waste port that sits between the waste section on the Transfer belt and the Waste Tone box?
    There was also a bulletin about said ports positioning on some machines. I've never had the issue. I've usually replaced the old model belt with the new model.
    EDIT: Inside that waste section on the belt, the toner can sort of get compacted on the waste port end and put just enough pressure on the end of the augur to put a slight bend in it, which sometimes can cause it to click. I'd clean all the solid bits out as well if there are any stuck in there.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4736
      Re: BizHub C360
      Thanks for the reply. I found tech bulletin on K/M dealer website. It basically is same as you said about cleaning out the waste toner pipe, auger, etc.
      Thanks again
      • WATTY
        • Oct 2014
        • 12
        Re: BizHub C360
        Thanks in advance
        Hello
        I had the same issue< the gears on the tbu cleaner assy had locked up, vac out the toner and it came back again, only way to fix it was to change the tbu>
        Good luck
