all UI and toner undetected on Minolta C203
  • kamalovitch
    • Jun 2009
    • 6
    need help please, the machine is operating normally, and this morning all yes and toner undetected on Minolta C203, it returns a message saying that we must put IU and toner when I replace the same problem,
    thank you.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: all UI and toner undetected on Minolta C203
    I would assume blown icp on prcb from/or a shorted tc or iu chip contact pin.
    • kamalovitch
      • Jun 2009
      • 6
      I have the problem on all iu and toners, the machine does not detect any
      • paulrid
        • Nov 2011
        • 206
        Have you just changed a toner or IU? I have seen similar things when data on one of the chips is corrupt.
        if so try changing it again.
        Paul.
        • kamalovitch
          • Jun 2009
          • 6
          Paul.
          I charge all iu but the problem persists,
          • paulrid
            • Nov 2011
            • 206
            and the toner?
            paul.
              • 22963
              Does KM have a place in the service mode where they designate what brand or badge will be displayed? Let's say it's designated as an Oce' and you've installed KM IU's and toners. =^..^=
              • Blizzoo
                • Aug 2013
                • 600
                IU lot number it's shown in service mode?
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  is it saying they arent inserted OR they are the incorrect type ?
                  • PeterG
                    • 177
                    If my memory is to be relied on, I seem to recall that this can be caused by bent, "shorting" contacts on one of the image units!
                    • bigmark
                      • Sep 2008
                      • 39
                      what logo shows up when you reboot the MFP? is it the rocket ship/outer space logo... or the KM logo. If its the outer space logo.. its also possible the NVRAM has blown, there is a recovery procedure and a few switches that have to be set to recover from this. another option is to print out the configuration page.. if it lists the model as a generic model... again, NVRAM issues.
