Bizhub C754 Cyan IU Failing
  • MVPunisher
    • 209
    The Cyan IU keeps failing shortly after putting it in. The middle of the page becomes washed out. Today I will check the waste toner box to see if DV is being pulled. Did not check this before as I was just suspecting a faulty IU.
    I am thinking HV unit>? any suggestions appreciated. Thanks.
  • Avind
    • Jun 2018
    • 6
    Re: Bizhub C754 Cyan IU Failing
    I have a question about C754 IU...just installed a new OEM Magenta IU and the counter in the service menu is 0 as it should be, but the percentage in the Consumable Life is 99%. Why? Do I have to reset or initialize something when I put the new IU in?
    • mincopier
      • Dec 2015
      • 289
      Toner hopper not adding toner to the developer unit. Could also be the mothers in the back not turning the hopper, toner, or DV unit.
        good job reviving a 5 year old DEAD thread!
        Now start your own.. and please take note of the DATE of threads you want to post on.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4738
          Simple, The counter in consumable life countdown, start (full) at 100% and empty at 0%
