C224e/C284e/C364e/C454e/C545e cyan dev unit problems
  • enricocopyline
    replied
    Re: C224e/C284e/C364e/C454e/C545e cyan dev unit problems
    but the problem that causes this cyan malfunction without having to replace dv every few copies?
  • Don N.
    replied
    Originally posted by Don N.
    We're having good results with dev from Clite on c220 series. Likely same dev in both series. Same gram weight in bag, used 4e dev in c220 all colors working fine. Some c220 Y overtone/dusting prematurely, like 20k. No resolution there yet. Good drums, ITB not at yield yet.
    Had to switch to Ktn developer. Clite Dv was unpredictable. You can use C220 series in a 4e, just pull out the initial toner with aboout 30 halftones at 255 after setup is complete to get the 4e toner in & the c220 toner out. DV is the same. NOW Ktn has 4e color DV' available as of 1/20... It's more expensive but would have the 4e toner in it already.
  • enricocopyline
    replied
    Was the solution found to this problem?
  • kmbthk
    replied
    vacuum the toner filter duct before replace new cyan dev
  • Don N.
    replied
    Not officially.
    However you can buy after market crap if you want to ruin your machine!
    We're having good results with dev from copylite on c220 series. Likely same dev in both series. Same gram weight in bag, used 4e dev in c220 all colors working fine. Some c220 Y overtone/dusting prematurely, like 20k. No resolution there yet. Good drums, ITB not at yield yet.
    replied
    Originally posted by jonbonse
    Can you get colour dev rather than buying the whole dev unit then?
    Not officially.
  • jonbonse
    replied
    Originally posted by allan
    No problem on my machines. The toner add does not work together it is the same as C360 only change is the reed switches was changed to Photo interuptors because of the developer bieng added to the toner it would get stuck to the magnet inside the sub hopper. Are you reseting the dev tanks? >dealer trick = buy only black Dev tanks and convert to color much cheaper<. The sensors cant see color only density!
  • habik
    replied
    Originally posted by rinser
    Has anyone come to a solid conclusion on what causes these cyan developers to fail?
    We have a few of these causing problems,
    On one 224e machine, only the drums were over life and the developer failed at 27k mono 65k colour, the machine was running oem toner
    We replaced the following:
    Cyan Dev
    all drum units
    High Voltage board
    updated the fw
    but the problem returned after 35k again.
    any ideas?
    Try vacuuming the ducts and change TX belt + TR.
  • rinser
    replied
    Cyan Dev
    all drum units
    High Voltage board
    updated the fw
    any ideas?
  • femaster
    replied
    Now, that's just asking for trouble. Lol
    Was thinking the same thing. With as many issues as they have with the OEM stuff, I wouldn't even want to fathom the problems with non-OEM!
    Sent from Tapatalk.
    replied
    Originally posted by Tech Helpdesk
    Good news, Katun are selling developers for the black units now !!!!
  • Tech Helpdesk
    replied
    The firmware wont correct a faulty dev unit, the firmware is designed to prevent a future cyan dev failure.
    You will still need to replace the cyan dev unit, or as I do keep the old units, pour out the dev & use it to top out others as they fail, its a cheap option but works very well.
    replied
  • Drcopy
    replied
    Originally posted by Drcopy
    I have just read all the posts from the start, because one of my techs is now having this issue with the cyan depleting and causing print quality problem.
    Replaced the parts mentioned in this thread and as we speak now updating the firmware, drum life (C,M,Y,K) are below 100% as well.
    Waiting to hear from the tech after the update.
    Just recieved confirmation firmware made no difference.
  • Drcopy
    replied
