We have some repeating cases with odd duplex jamming. 2 machines has been swapped because we haven't found the cause, another is is currently an open case. It happens at irregular intervals.
This is what happens:
Machine put the duplex job directly towards and completely out of the paper exit output instead of moving it further upwards to the duplex-exit - like if you do a single copy
Jam counts are added up at "Paper Exit".
These parts has been swapped during investigation:
- all involved sensors
- paper exit junction gate + magnet
- paper exit unit (complete assy with gates...)
- exit drive motor
- printer control board
- paper reversal unit
We haven't much B/W models in the field and it seem that the problems does only come up with the first production batches. Paper path is pretty much the same as the COL engine and we have plenty of them in the field with no such issue.
Perhaps you guys have some hints because I'm not fancy about entire MFP swaps.
- exit drive motor
