BH284e series - weird duplex jams
  • Gift
    • Mar 2011
    • 2459
    [Jamming] BH284e series - weird duplex jams
    We have some repeating cases with odd duplex jamming. 2 machines has been swapped because we haven't found the cause, another is is currently an open case. It happens at irregular intervals.
    This is what happens:
    Machine put the duplex job directly towards and completely out of the paper exit output instead of moving it further upwards to the duplex-exit - like if you do a single copy
    Jam counts are added up at "Paper Exit".
    These parts has been swapped during investigation:
    - all involved sensors
    - paper exit junction gate + magnet
    - paper exit unit (complete assy with gates...)
    - exit drive motor
    - printer control board
    - paper reversal unit
    We haven't much B/W models in the field and it seem that the problems does only come up with the first production batches. Paper path is pretty much the same as the COL engine and we have plenty of them in the field with no such issue.
    Perhaps you guys have some hints because I'm not fancy about entire MFP swaps.
  • HoonBoy
    • May 2011
    • 130
    Re: BH284e series - weird duplex jams
    The most common problem is that the foam cushions for the duplex turnover guides get sticky and the guides get stuck... J-3201 and J-3205 it will cause.
    If the paper is very moist it can also genarate these kind of jams, set warmup mode to 3 or 4 and lower the fusing temparture or fusing speed could also help.
    I had one machine with weird (duplex) jams(J-2002 and J-9202)... and it ended up being the registration actuator spring that was not put correctly(factory).
    The spring was put twisted...
    Good luck!
      • 8174
      Personally the FIRST thing I do on any KM is update the firmware, infact I flash the firmware on EVERY KM I visit, only then do I trouble shoot.
      • Gift
        • Mar 2011
        • 2459
        Thanks for your replies. We always keep firmware up to date so I can easily outrule that. Sticky cushions are a bit unusual when it comes to machines that are just a few month old but this has been outrules, too since the involved parts has been replaced. Will check this reg actuator spring, tough - thanks
        • CraigW
          • Dec 2010
          • 417
          What jam #s are you getting on the management list ???
          • wseyller
            • Sep 2012
            • 1129
            Reminds me of an issue I saw in this thread. http://www.copytechnet.com/forums/ko...2-01-jams.html
            I was assisting another tech with it and I was told he was going to replace the prcb but never heard if he resolved it. If I see him next time I will ask.
            • fishleg
              • Mar 2009
              • 426
              We have seen this a few times, remove sticky pads both sides usually fixes it. Had one time where it was the exit noid as well but only once.
              • deepdiver
                • Dec 2013
                • 13
                I have had about 6 copiers with J32-05. This problem I thought was to do with their paper (70gsm) but I have also seen it on 80gsm paper as well, though not as much. It is mainly to do with DUPLEX printing and paper curl. All their copiers are default set to DUPLEXAttached is solution as found on info hub.
                If you don't want to read it, simply change these 2 settings.
                Change the warm up mode.
                Service mode > System 1 > warm up & set to MODE 3
                Service Mode > Machine > Fusing Temperature & set to -10
                So far this seems to have worked
                • wseyller
                  • Sep 2012
                  • 1129
                  Still dealing with this issue on a C554
                  3201 jam codes
                  Only seems to happen on the first page or when paper runs out and job starts back up.
                  Updated Firmware
                  Changed:
                  Fuser
                  Fuser Motor
                  Duplex reverse section which includes duplex gate and soleniod.
                  MFPB
                  PRCB
                  On Friday changed the warmup and temp as suggested above and still does not help
                  Customer is using Georgia-Pacific 20lb (75 g/m2) 92 bright
                  • Kombucha01
                    • Oct 2013
                    • 2
                    Hello! Any news with this problem ? I got the same problem today ...
                    • wseyller
                      • Sep 2012
                      • 1129
                      I don't know exactly the detail of this but another tech at our office had two of these and changed everything related. Somehow he managed to add some electrical tape somewhere for the duplex gate that either kept it from actuating either too little or too much. But it is something with that gate and he was able to finally make it work consistently.
                      • Synaux
                        • Mar 2012
                        • 1224
                        3201 jam codes
                        Updated Firmware
                        Changed:
                        Fuser
                        Fuser Motor
                        MFPB
                        PRCB
                        I dunno, but that Georgia-Pacific 20lb (75 g/m2) 92 bright paper is a little on the crappy side.
                        Each ream is cut to a different size and if they are getting it at Walmart, those idiots must be bouncing the boxes off shit and throwing them across the warehouse with a overhead crane or something. I have never seen anything like it.
                        I tell everyone to run 22-24# paper and train them on how to fan the paper (all four sides--seems to reduce a lot of paper dust).
                        • renot
                          • 6
                          Has anyone been able to come up with a fix for this problem? I have had limited success by removing part of the return spring that goes to the gate, but the problem returned about a month later.
                          • Dijan
                            • Jan 2012
                            • 16
                            same weird problem, check the Photointerrupter(PS1) in the CONVEYANCE SECTION did not work well
                            We have replaced Photointerrupter problem solved!
                            • eaglecopier
                              • Aug 2012
                              • 1
                              Thanks for the information
