konica minolta d351 install image unit
  • javier4065
    • Feb 2007
    • 251
    I have a big prblem with this copier dialta 351 display says install image unit no change, I put a fuse, and the copier is ready then I open the right door and close it ,install image unit is displaying again. thanks.
  • deep
    • Jun 2008
    • 208
    "Install Image Unit" means the machine cannot detect the IU.
    Take it out and clean the metallic contacts on the side frames.
    Kenny
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Go back to where you put in fuse, if you left it loose it may not be making contact.
      • DarthAlbin
        You will also want to make sure the fuse is of the proper rating. An over or under rated fuse will not clear the code properly. If it's an under rated fuse, you may need to replace the fuse again. Ohm out the fuse to make sure it hasn't blown already.
        • deep
          • Jun 2008
          • 208
          Please note the title of the original poster.
          Kenny
          • javier4065
            • Feb 2007
            • 251
            minolta di351
            thanks for your answers but I can not solve it.I clean all contacts into machine and the imagen unit too.I want to know how the copier check the imagen unit, Any suggestion. I am sorry but I don write english very well I am from peru thanks
            • deep
              • Jun 2008
              • 208
              Make sure the IU is properly installed. You should push the IU all the way into the copy machine.
              What is the message shown on the screen? (Install Image Unit or Replace Image Unit) ?
              I want to you to check it again. It is a big different.
              Kenny
              • javier4065
                • Feb 2007
                • 251
                minolta di351
                thanks for your help deep ,the message is install image unit , I pushed in it all the way. I can close the right door. The customer said me that the screen was displaying replace imagen unit,but the machine was copying. this week the copier was stopped and the message replace imagen unit was not blinking. He called a technician and he put the fuse and he didnt back.now I have this problem.
                • deep
                  • Jun 2008
                  • 208
                  You should notice that there are two components connected on the connector, one is what we call it a "fuse" (1/16 Ohm) for reseting the "Replace Image Unit" Message. The other is a resistor (~38 Kilo Ohm). Check this resistor with a multi-tester. Make sure it is good (Not open circuit). Also check the "golden contacts" on the connector are all good.
                  If the error persists, try it with a known good image unit. If the "Install Image Unit" Message is still there, there may be something burnt by putting the fuse incorrectly.
                  Kenny
                  • javier4065
                    • Feb 2007
                    • 251
                    minolta di351
                    thanks mr. deep where is the 38 kilo ohm resistor? I need solve this machine.
                    • deep
                      • Jun 2008
                      • 208
                      I hope it can help.
                      Kenny
                      • DadO
                        • Dec 2007
                        • 404
                        When u take out the drum unit look at the connector whit an golden pins on it. Under it should be an 2 black screws. Check the 1/16 resistor.It should be whit green color(depends from manufacturer) . Drum ratings in Service mode should be under 205.
                        • DadO
                          • Dec 2007
                          • 404
                          lol deep we posted in same time
                          • deep
                            • Jun 2008
                            • 208
                            No Sir.....I'm one day earlier.
                            Kenny
                            • javier4065
                              • Feb 2007
                              • 251
                              minolta di351 install imagen unit
                              Thanks friends ,You have the reason the resistor was open. That was all the problem.
