B601 Background
  • allan
    RTFM!!
    • 5462
    [CQ] B601 Background
    Hi Guys
    I have this one B601 that is giving me a bad background, i have seen this before but was not my problem to fix, that machine ended up scraped so im not sure how to fix this.
    Did clear counters.
    installed new drum, dev, blade. 600k on the clock
    check dev bias connection to be 5 ohm which is good.
    check grid voltage to match new drum.
    contact springs is all good.
    changed charge unit.
    check all voltage setting with other machine to make sure it is in same range.
    changed the dev unit.
    Please look at the sample.
    Help is very welcome!
    Line on the one side is a bad UFR.
    Whatever
  • allan
    RTFM!!
    • 5462
    Re: B601 Background
    Really? nobody seen this?
    Whatever
      • 14817
      Re: B601 Background
      Run 30 to 50 skyshots, run drum peculiarity, that should do it.
      • allan
        RTFM!!
        • 5462
        Re: B601 Background
        Thanks someone gave me the same advice today.
        Also to run thru the dipsw to see if there is some tapering. I got the machine secondhand.
        The thing is its not over toned. The dev tank work perfectly from the first copy in another machine.
        Whatever
        • bizhub1
          • Sep 2008
          • 230
          Re: B601 Background
          I just had one do this, and changed softswitches and cleared right up. Changed sw 23-2 and 23-3 from 0 to 1. Also change 5-0 to 1
          • allan
            RTFM!!
            • 5462
            Re: B601 Background
            Thanks i will try those.
            Whatever
            • tinto89
              • Jul 2012
              • 23
              Re: B601 Background
              clean the erase lamp (or replace it)
              clean the charge black plate
              and run the drum peculiarity adj.
              • allan
                RTFM!!
                • 5462
                Re: B601 Background
                Turn out to be a bad sensor board. I would keep the dip switches in mind Thx.
                Whatever
