C452 Light patch on halftone prints
  • habik
    • 2013
    Hi There
    Have MF451 (Bizhub C452) that has patching running on the bottom of the page. It happens on all colors.Turned paper 180 degree patching still happening on the bottom so it isn't the paper. 450k on Transfer belt but no visible patchy marks or any marks in fact what so ever. My eyes are sharp but don't see any obvious movement of transfer belt during the door open. Stabilization runs fine. Cleaned HV contacts on ITB + TR + inside machine( not on the back where HV board sits though). Cleaned IDC's front and rear- Re-run Stabilisation background reset and |Gradation. reboot - Trouble Reset - Checked again ITB for any broken/ cracked primary roller brackets. Nothing obvious. So I concluded either HV board or Transfer Belt or Transfer roller. Going to change ITB, just wondered if anyone had this so I don't run 3 times to a client.
    Many Thanks see attached pdf.MF451 HALFTONE 1PC BK.pdf
    Firmwares HERE
  • Max
    • Oct 2011
    • 557
    Re: C452 Light patch on halftone prints
    measure the distance between the patches and take it from there. Is it the same on all colours or just K? I would say your K dev unit had it as the solids are very uneven. If i had to guess I would go for the image belt or fuser belt if the patches are not too far apart.
    • habik
      • 2013
      All colours same place same spot sloght variation in size
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • Dougtech
        • Apr 2011
        • 113
        I see the sample has mixed colors - what do the individual CMYK test prints look like?
        • habik
          • 2013
          Back on site. Changed ITB and TR
          problem persists
          Firmwares HERE
          • habik
            • 2013
            Replaced paper different brand. Problem remaining. Doesn't do it at all on A4. Tried running single color A4 cyan, magenta, yellow all good.
            So it is definitely A3 issue as it happens on 2nd half.
            Machine just passed 1 million. Data from Listoutput:
            Transfer Roller 431k - Changed
            Transfer Belt 48306 - Changed
            CMY IU's - 1380M (43k) Changed recently
            Drum K - 1521M (50k) Changed recently
            Taking new dev and fuser as that is the last bit before I take machine apart.
            Dev K - 700k -
            Fuser 281k
            Firmwares HERE
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              fusing loop actuator clean and unbroken ?
              tried increasing printer reg loop from tray 1/2 ?
              Enormous groove worn into grey guide bellow IDC sensor housing altering paper path length ?
              • habik
                • 2013
                Thanks EarthKmTech. I will check that groove next time! And will keep your tips in mind.
                It turned out to be fuser. I'll post pics later.
                Funny bit is that when I run paper 3 times as blank copy and tried halftone the issue wasn't showing. Meaning paper got harder grains shorter so not much movement and that lead to the fuser but I never had one to go at 280k. They last 2x as much.
                Firmwares HERE
                • Max
                  • Oct 2011
                  • 557
                  I new it :-)
                  • habik
                    • 2013
                    I new it :-)
                    Well
                    My experience is that patches travel. Like drum length fuser belt length dev lenght ITB or TR length. So when you print 20 A3 in a run you'd see the patch moving. Since it looked like stain mark I thought it is paper.. Changed paper and stain was different in size and shape but still in the same spot.
                    Firmwares HERE
                    • hotfuser
                      • 180
                      Originally posted by habik
                      Well
                      Was the fuser unit rippled on the LFR (bubbling/coating coming off) this is quite common on high milage units.
                      • habik
                        • 2013
                        Yes. Not a heavy wear. The fuser done 281k only.
                        Whats the cause? Age!?
                        Firmwares HERE
                        • hotfuser
                          • 180
                          yes mate it is just age
                          • habik
                            • 2013
                            Getting old I am,
                            cheers everyone have a nice weekend!
                            Firmwares HERE
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              This engine destroys fusers when used exclusively on A3, they will start to crumble the pink sponge under the sleeve at around 40-50k and by 100k the entire sleeve shreds. Absolutely nothing can be done about it either, had multiple brand new machines out of the box doing it at one customer till we gave them something with a real fusing unit - not this instant on induction rubbish.
                              The more A3 a customer prints the more likely the fuser is to fail before end of life.
