Bizhub 421 - Streaks in subscan direction
  • Victor285
    • Jul 2010
    • 61
    [CQ] Bizhub 421 - Streaks in subscan direction
    Hey Gang,
    I have a Bizhub 421 streaking in subscan direction. I have taken out and cleaned drum, blade and charge grid, vacuumed out toner waste well and re-assembled. Also scrubbed corona wires with sos to shine, wiped w/ iso wipe. The quality got much better but is still showing some streaks. (See attached) cleaned laser glass as well. Plan on replacing Drum Blade next. Wanted to know if there are any other parts that would add to this defect. Unit is approaching 300,000. Thanks for all helpful comments. V
  • Victor285
    • Jul 2010
    • 61
    Re: Bizhub 421 - Streaks in subscan direction
    missing sampleBzhub421_lines in Subscan Dir_20150225.pdfbhub421_H line in Subscan Dir_20150225.pdf
    • SAR
      • Jul 2009
      • 199
      It's probably the drum. The life is supposed to be 250k, but they crap out at 300k!
      • CraigW
        • Dec 2010
        • 417
        Drum scuff...... you should be able to see it.
        Go easy on cleaning those charge wires, or you will break the crappy little pin in the block.
        • Victor285
          • Jul 2010
          • 61
          update; Changed the Drum Blade and refit side seals and that seemed to have gotten rid of 98% random streaking. It didn't completely remove all marks as I'll get a hint of a faded stripe in say 1 out of about 15 pages. Next step will be drum. Thanks again for your help.
          • Victor285
            • Jul 2010
            • 61
            If it is the drum scuff. Can you replace just the drum on these or do you also have to change developer at the same time? Service Manual says that you have to reset counter or you may get fogging or toner splash. Thanks for reply, Vic
            • CraigW
              • Dec 2010
              • 417
              The 2 have the same rated life of 250k.
              Where are they at ??
              • Victor285
                • Jul 2010
                • 61
                Drum is 209,000
                Developer only
                36,000
                • CraigW
                  • Dec 2010
                  • 417
                  I think it would be safe to do drum alone. And reset the drum counts also.
                  • Victor285
                    • Jul 2010
                    • 61
                    Thanks for the quick followup, CraigW. I'll report back later.
                    • allan
                      RTFM!!
                      • 5459
                      Originally posted by Victor285
                      Hey Gang,
                      fuser web and the funky B421 style reset.
                      That looks like blade failure. I never replace a drum without a new blade.
                      Whatever
                      • CraigW
                        • Dec 2010
                        • 417
                        Post #5 said the blade was replaced.
                        Never liked that set-up..... not one bit.
                        Take away my wonderful 7045s, and give me a sped up 7020. Only advantage is the 250k pm cycle.
                        • Albonline
                          • Sep 2008
                          • 1133
                          try increasing grid voltage a bit, may hide problem, and put off drum replacement for sometime.
                          • allan
                            RTFM!!
                            • 5459
                            Its one of those tweaky machines like its big brother the B601.
                            Whatever
                              • 14410
                              Yes, it is nice to see all the legacy Konica crap is out of production at Konica Minolta.
