we got a customer a used konica 222. worked fine for a week and then started having paper feed trouble in top drawer. would only pick up paper but not advance it. i cleaned feed tires and it worked for a few days and started again. told custoner i would order feed tires and to put paper in 2nd drawer whidh i had also cleaned. worked for a few hours and then same problem. i find it hard to believe that both drawers need new feed tires, could this be another problem.
konica 222 feed problems
Re: konica 222 feed problems
we got a customer a used konica 222. worked fine for a week and then started having paper feed trouble in top drawer. would only pick up paper but not advance it. i cleaned feed tires and it worked for a few days and started again. told custoner i would order feed tires and to put paper in 2nd drawer whidh i had also cleaned. worked for a few hours and then same problem. i find it hard to believe that both drawers need new feed tires, could this be another problem. -
Ah! An opportunity to step up on my soapbox!
You may have slipping one-way bearings in the feed units. Quite often, these one-way bearings are not treated correctly.
You'll want to soak out the one-way bearing (aka Torrington) in alcohol, and run a Q-tip around the opening. When it's dried a little add a single drop of light oil (like Triflow) to the bearing.
Check the shaft for wear. It's OK if it's smooth or shiney, but not OK if it has worn down in size/diameter. If the plating has peeled off you'll need to replace the shaft. It is common practice (and completely wrong) to score up the shaft with steel wool or green scrubbie. This action damages the shaft, forcing you to replace it. The one-way bearing needs the maximum surface contact with the shaft, and scoring up reduces the surface contact, and reduces the shaft size.
Some techs replace these one-way bearings every other tire change, or even every time. =^..^=
<<blackcat steps down off his soapbox>>If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
<<blackcat steps down off his soapbox>>Comment
They absolutely must be oiled. I have some information somewhere about Torringtons:
See page B257 regarding lubrication. I don't claim to understand all (or much) of the engineering data, but I can be certain the the shaft must not be worn down, scored or damaged, and the bearing must be lubricated.
Do not feel like you have to be silent. That is what the forums are for: airing of opinions. Sometimes we agree. Sometimes we don't. No harm, no foul. =^..^=If you'd like a serious answer to your request:
electronic Clutches shoud never be oiled , but using alcohol to check if a clutch is sticking is a tool techs use. Spring loaded clutch shoud be greased on the boss and spring.
to understand why, go to US patent website and see how they are designed and the science of their mechanics.
Like you, i could not understand this in my early years of troubleshooting. techs must understand how these work as it goes a long way in troubleshooting.
If you can turn a one way bearing with your hand then that bearing and shaft is good. most of the time it will be the shaft that fails, as those bearings are made of very hardened steel.
ENGINEERS GIVE YOUR INPUT HERE. REPLY TO THIS THREADLast edited by subaro; 03-22-2015, 11:48 PM.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
voice your opinions on this subject. there are lots of junior and senior techs who need to hear your voices.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Here's an example of a worn shaft that I came across last week. This is on a Canon iR5055, but it demonstrates the point:
If you check the 1-way in ADF, you'll see it nicely oiled up. And it has plastic casing (#Hansoon).
I've used few oils and so far gearbox oil does the trick. But first a good spray with IPA to get the muck out use corner of lint free cloth(cotton sheets although the new sheets are crap as they semi/synthethic)
Also there is bulletin for side door on vertical path which you want to check and a conveyance roller in vertical path.
I know the feeling of 2nd visit final fix! Good luck mate and heads up. We are all humans and so is the client! Just smile
I change them every 2nd tyre change(mark it wit permanent marker)
Sent from my iDon't believe in marketing device using TapatalkComment
My 2c worth!
Regards!
A.Comment
This pertains the feed units on multiple KM machines particularily. PREVIOUS REPLY
DOES KM refers to konica minolta or kyocera mita ?
It is good that the replies about one way bearings are coming in. So far, techs are posting with diffrent methods they use to clean and lubricate or not lubricate them.
aslo good to hear opinions on electronic and spring loaded clutches . service or just replace ?
LET THE VOICES KEEP ROLLING.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
Konica electric clutch full metal type C650 tray 3 and such > duster or replace only.
Kyocera - disassemble clean plates with WD40 to get rid of rust and residue. Then IPA to clean off the WD40 from the clutch plate contact area. Assembly. (TA5500i series)
The clutch part# is 9322 1500 12.
Hope this helpsComment
