Scanner Lock Error
  • austria
    [Error Code] Scanner Lock Error
    I have a bizhub 42 which is showing scanner lock error even the scanner lock is open. I tried to reset the machine and reconnect the harness but i still got the same problem. Can someone help me with this?
  • Albonline
    • Sep 2008
    • 1153
    Re: Scanner Lock Error
    something is keeping the optics from moving.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      open optics and move scanner to center of machine. power on if the optics do not move and code returns then replace the mfp board.
      • Dijan
        • Jan 2012
        • 16
        try latest firmware update!
        It helped me at a C35
          • 23010
          Have attempted to move the scanner manually? It sounds a little like you haven't actually done anything yet. =^..^=
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            looks like an end user - probably best to call a tech.
