i need help c5501 bad transfer in hevy paper, in normal paper is correct the copier.
  • jcarlos64
    • Sep 2010
    • 4
    [CQ] i need help c5501 bad transfer in hevy paper, in normal paper is correct the copier.
  • Mick01
    • Nov 2012
    • 362
    Re: i need help c5501 bad transfer in hevy paper, in normal paper is correct the copi
    Looks like insufficient transfer to me. How thick is the stock (in microns not gsm)
    Try increasing second transfer firstly. If no improvement i believe it will be neccessary to rebouild the transfer belt unit and replace the second transfer roller lower.
    Hope this helps
    • jcarlos64
      • Sep 2010
      • 4
      Hope this helps
      thanck you
      but I change the roller transfer, too the unit belt transfer.
      the charge unit is new (4)
      • RAI
        • Feb 2014
        • 44
        By chance is the toner non OEM? I just had a case of non OEM toner not transfering on heavy stock only. I rebuilt the itb assembly, replaced the dev, change the Chargers, the charge settings. Added humidity. I ended up flushing out the toner and replaceing with OEM and everything returned to normal. Oddly the effect was really noticed on MO and ML heavy paper and linen.
        • jcarlos64
          • Sep 2010
          • 4
          the toner is original
          • Albonline
            • Sep 2008
            • 1150
            did you try new paper? this looks like a moisture issue.
