C6501 C4721 then C4101
  • Choclit008
    • Apr 2015
    • 17
    [Error Code] C6501 C4721 then C4101
    C6501 / 2.2M copies / FW GN3-70 / PM kit installed 1 week previously
    The customer was printing when Black dropped out of the prints eventually popping C-4721 K write unit 12V code.
    I power cycled twice with code recurring both times during power up.
    Then I pulled the K write head ( 4 connectors), blew the dust off & reinstalled it.
    Since then only C4101 codes come up (yellow polygon motor)
    I temporarily swapped Y & M units to see if the code would follow the unit - it did not.
    I was advised to check all connections on harnesses going to the write units (uplugged & reconnected) but this did not resolve anything.
    I inspected the harness back to the PRCB.
    I have swapped the PRCB - no change.
    Started the unit in tech mode & tried to start the polygon motors for the write units but do not hear anything.
    Pulled the top connector off all units (polygon wires) & powered on - same code
    Seems to be a phantom code
    Suggestions? I don't understand what would have caused the 2nd code
    I will probably try to swap K write unit & IPB next to see what happens
  • Albonline
    • Sep 2008
    • 1150
    Re: C6501 C4721 then C4101
    swap out k write unit, think it may be loading the power supply.
    • Choclit008
      • Apr 2015
      • 17
      Thanks - will do that next
      • Choclit008
        • Apr 2015
        • 17
        Have swapped PRCB IPB & write unit/K and still getting C4101 code.
        Have confirmed continuity in harness from Y 9Pin connector to PRCB connector 651
        With door open so unit does not code voltages are consistent across all write units on the 9 pin connector.
        Output check does not seem to turn polygon motors on - I can't hear any noise at all.
        Will order harness per KM support but I don't think I have any broken wires in it.
          • 23007
          How about the 12v supply? Where is it coming from, and is it consistently present? Shorting to frame ground?
          On a Toshiba recently, I assisted on a toner motor issue, which after much metering of harnesses brought us all the way back to the filter board. That 5vdc lead was shorting out a 5vdc logic level, which happened to include the toner cartridge rotation sensors and the toner motors. The point of this digression is that a short can take you anywhere in the machine. There is no logic to it. =^..^=
          • Choclit008
            • Apr 2015
            • 17
            All the voltages on the PRCB looked ok
            I found 3 12V points on the wiring diag for DSCP/1, none on /2
            I will give that a look in the morning - I was starting to wonder about power issues...
            • Albonline
              • Sep 2008
              • 1150
              try dcps2 24v2-2 is sourced from there, connector 127.
              • Choclit008
                • Apr 2015
                • 17
                RESOLVED
                Bad M43 fan motor that appears to spin normally was at fault.
                My Service Manager decided to replace it & the C4101 code did not happen.
                To test I opened the front door and plugged the suspect fan back in and code happened right after I closed the door.
                After unswapping PRCB, IPB & Kwrite unit the original C4721 code came back.
                Swapped the loaner K write unit back in and unit is fully useable.
                Also - there are 5 fans & a TEMS/HUM unit mounted on the frame & no way to keep it off to the side so I completely disconnected it & set it aside as it did not appear to cause any fan codes which I expected to show up. This obviously is faulty logic. Don't do it.
                My SM thinks it is time to replace all 5 fans -the unit has 4 & 1/2 yrs of use now & will be kept in use for the foreseeable future.
                Thanks for the input and hope this helps someone else - watch out for those fans.
                  • 23007
                  Congratulations on your success. =^..^=
                  • tulintron
                    • Jul 2014
                    • 668
                    Originally posted by Choclit008
                    RESOLVED
                    PERFECT! I came across a similar problem and I was able to solve it after reading your post !!!
                    • tulintron
                      • Jul 2014
                      • 668
                      • zmeutz
                        • Nov 2014
                        • 27
                        RESOLVED
                        Is the same also for 4102? (M43 fan motor)
                        I don't find this error no where...
                        thanks!
                        stefan
                          thanks!
                          stefan
                          well then your MACHINE may not have that fan nor that code in firmware ...
                          RTFM
                          oh and STOP posting on a DEAD thread that has been solved years ago...
                          Different machine START YOUR OWN LIVE THREAD!
