Konica Minolta 362 how to do a full reset on the machine in service mode
  • Alex1
    • Oct 2012
    • 285
    Hi,
    I have a Konica Minolta 362 and I need to do a full reset on the machine in service mode.
    the machine receives faxes ok, and sends to local numbers ok, but when I try and send to interstate or to 1300 numbers it's keeps saying wait and eventually redial and report comes back NG. Any help would be appreciated.
    • 23003
    Re: Konica Minolta 362 how to do a full reset on the machine in service mode
    Do you really think that will help? If it were me, I would try different settings for ECM, transmission start speed, and equalization. =^..^=
    • Alex1
      • Oct 2012
      • 285
      Thanks for your reply
      where would I check these settings?
      I just wanted to make sure that all settings are back to default
        • 23003
        This reset you desire is like using a sledge hammer on a loose screw. Better to check these settings individually. You don't have a manual? It took me exactly 10 seconds to find a service manual using Google, here: ftp://195.91.159.71/ineo%20222%20282...Operations.pdf
        Another thing I don't do, is I don't read manuals to persons perfectly capable of reading for themselves. RTFM. =^..^=
        • copytechman
          • Nov 2008
          • 934
          Machines arent usually that choosy, phones lines can be though, Have you hooked up a regular telephone to see if you can dial those long distance numbers manually?
          Regards!
          A.
          • Alex1
            • Oct 2012
            • 285
            Regards!
            A.
            i know that was my thought as well. There was a Toshiba connected previously and that was dailing to interstate and 1300 numbers fine.
            • copytechman
              • Nov 2008
              • 934
              I'd still try the phone thing myself first. And then go from there.
              Regards.
              A.
              • CraigW
                • Dec 2010
                • 417
                VOIP phone line involved ??
