C224e with code C-9401
+ More Options
Posts
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    #16
    Re: C224e with code C-9401
    One df you could unscrew plate....other I bent it over lol
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      #17
      Originally posted by CraigW
      How in the world do you get to the screw on the white cable clamp ?? (or is THAT the tough portion ?)
      some people just cut that clamp off or cut the old cable end off when removing - I'm not one of them, but i've not heard of any issues in doing it - many have been done like this now without issue.
      I remove the 2 big disk head screws that secure the feeder to the frame and rest a screwdriver handle between the feeder and the frame to hold it up while I undo that clamp screw. It's not that hard really.
      KM did actually create instructions for replacement of the DF701 cis cable. I have not seen if for a long time though but it does exist. In typical KM fashion a ludicrous amount of disassembly was required in their version so i filed it in the circular filing cabinet - it came out months after i worked it out for my self.
        • 23010
        #18
        I got those instructions. Like yourself, I balked at the vast complexity and just figured it out myself. =^..^=
        • Imsdal
          • Aug 2009
          • 111
          #19
          Kidaver...
          what old bulky black Cable do you mean..
          Do you have any number for that item..
          Sincererly
          David
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            #20
            A3CEN11711 is the part number. It is the black cable that runs from CIS down to the dual scan pwb. Old one is thicker than the new cable.
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              #21
              Oh, but you will be doing it again
              I've had machines sold up till recently still fitted with the fat cable and had to change it. Not everyone does it though, still got LOTs of df-701's in the field with the old style cable still going fine. The problem seems to occur most on machines where the rear hinges have not been setup correctly, ie left in the factory position and the DF is able to open all the way to 90 degrees.
              I am cursing your name this morning as I had a call come in for C454e with c9403 code...
              • nickel123
                #22
                had this problem on a new 224e during set-up. replaced the scanner assy.
