c35 smtp authentication get lost
  • yosif1
    • May 2012
    • 6
    hi I have c35 that after I configure everything and scan to email work fine
    when turn the machine off and on the smtp authentication setting changed
    to disable and the machine does not scan to email.
    tried to replace the battery on the mfpb and nothing change.
    any help?
  • copier tech
    • 8136
    Re: c35 smtp authentication get lost
    Have you tried updating both the firmwares?
    • yosif1
      • May 2012
      • 6
      can't remember if i made firmware update before or after the problem
      anywhere i will try firmware update
      but what it mean both firmware?
      • copier tech
        • 8136
        We'll there's two firmware files for this model, engine & controller
        Controller version is now Maintenance Release 10
        & with the later engine firmware you can extend the life of the image units, this is very useful
