Bizhub 364e blank copy & prints
  • apollo
    • Mar 2008
    • 191
    [CQ] Bizhub 364e blank copy & prints
    Hi gents
    I am getting Blank copy and prints, and also any reports from service mode, copier only 6 months old from new.
    Tested imaging unit with C364 and its fine.
    No image when you stop copy half way, no image on itb and drum
    dev gear all fine and turning, transfer rollerfine as well.
    spoke to km technical dept and suggested change DIMMs memory as not writing data, which i have done today.
    still same issue .
    Now they saying could be main controlloler or HVT board, not laser as it would throw up error code.
    any one had any similar fault can shine some light into this issue.
    any input will be much appreciated.
    thanks in advance.
  • wseyller
    • Sep 2012
    • 1129
    Re: Bizhub 364e blank copy & prints
    It could be the laser if light is blocked. Try defeating the interlock on the front door and pull the drum corona cleaner out half way and run some prints.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      it'll be the hv board.
      there will be an open icp.
      • JasonSBE
        • Apr 2014
        • 187
        Can you scan? Either to a computer or a thumb drive? If it's memory it will probably be blank just as when you print. If it's an imaging issue(charge, print head, etc.) then scanning will work still.
        • jwrycza
          Office Systems Expert
          • Sep 2013
          • 90
          HV unit has failed. I have done 2 so far and they were both on low copy count machines.
          • apollo
            • Mar 2008
            • 191
            Hi
            yes i have ordered hvt and main controller so will update you guys,
            when i visit customer.
            scanning is all good.
            • apollo
              • Mar 2008
              • 191
              Hi
              Just an Update guys problem resolved after fitting HVT board.
