Konica Minolta C253 2 Green Lines
  • mearmi
    • Oct 2010
    • 350
    [CQ] Konica Minolta C253 2 Green Lines
    Konica Minolta C253, Getting 2 Green Vertical Lines on Print/Image and on half tones as well
    Did Gradation, Stabilization but problem still exists.
    Please find the attached sample image.
    Thanks and Regards,
    Mearmi
  • Blizzoo
    • Aug 2013
    • 610
    Re: Konica Minolta C253 2 Green Lines
    How are halftones tests?
    • mearmi
      • Oct 2010
      • 350
      There is line as well
        • 14970
        I would say you magenta IU has a void area in that spot. Try cleaning the printhead.
        If that doesn't fix it you can try disassembling the IU and fixing it that way.
        Otherwise replace it.
        Hope this helps.
        • allan
          RTFM!!
          • 5462
          I have made a special tool to clean the laser glass on these machines those swabs only push the dirt around.
          Take a blower brush and attach a rubber pipe to it then you can lift the shutter and clean the glass with air.
          Whatever
          • Gift
            • Mar 2011
            • 2459
            end user question here
            • mearmi
              • Oct 2010
              • 350
              Thanks a lot Allan. By cleaning the laser and replacing IDC sensors. Problem has gone.
              • mearmi
                • Oct 2010
                • 350
                Thanks a lot for your help. BY replacing the IDC sensors. Problem has gone.
                • Gift
                  • Mar 2011
                  • 2459
                  impressive...
