Hello, having constant issues with a pro 951 using ncr paper. the paper is run through an lct so it is a straight shot to the drum, no bend. the issue is a constant 7220 jam in the finisher. the paper is curling and getting caught on the exit of the finisher as the gate goes down. I have reduced the pressure of the fuser rollers and even reduced the fusing temp. works for a little while then jamming. there is more than a 10mm curl in the paper. I know the ncr is the big issue but this customer has been using it for years with the same supplier and no jamming. now, all it does is jam. losing my mind with the constant jamming. ant help or suggestions would be wonderful!!!!
Thanks!
Thanks!
