c280 stuck
  • jonpaul
    • Jul 2014
    • 59
    c280 stuck
    I m beginning to hate this model!!! A C280 stuck in warm up or KM screen,disconnected hard drive, updated firmware , reintialized all data,it will not let me into Admin so can't check power save setting.Tried to reboot on many occasions, I'm running out of ideas and patience.Thank you for any suggestions.
  • Max
    • Oct 2011
    • 558
    Re: c280 stuck
    Try resetting the nvram using the nvram reset procedure. Should be on km website.
    • Gaffers01
      • May 2011
      • 335
      Re: c280 stuck
      If this is the model with the ssd its knackered and will need to be sent back to KM for a replacement.
        • 23008
        Re: c280 stuck
        I'm pretty sure the C280 is pre-SSD. IIRC the "e" series is the first SSD product. =^..^=
        • wseyller
          • Sep 2012
          • 1129
          Re: c280 stuck
          I think the C280 has an ssd but it doesn't have the ssd problem like the E series. On the E series the ssd includes the nvram built in where as the C280 it is separate.
          Sent from my XT1254 using Tapatalk
