Kyocera KM-5035
  • PCTECHMECHANIC
    • Jun 2015
    • 14
    Kyocera KM-5035
    It was running fine and making copies like its supposed to and then and hour later they went back to make copies and they got error code 6000 and now it shows error code C6050.
    Any help or advise is greatly appreciated. Thank you in advance.
  • cm79
    • 20
    Re: Kyocera KM-5035
    Fixing unit errors, Low fixing unit thermistor temperature.
    Sim 163 to reset error.
    • PCTECHMECHANIC
      • Jun 2015
      • 14
      Re: Kyocera KM-5035
      CM79,
      Do I just punch in those numbers or is there more to it?
      Thank you for your response.
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: Kyocera KM-5035
        You may like to search Copytechnet for 10871087.
        Save the below link to your Favourites Toolbar. It can be handy.
        Copytechnet Forum Search - Via Google
        Alternatively you can type into your search engine or address bar.
        http://www.google.com/search?q=10871087&sitesearch=copytechnet.com
        • PCTECHMECHANIC
          • Jun 2015
          • 14
          Re: Kyocera KM-5035
          I entered 10871087 then 163 then the start button then execute then the start button again. It restarted but still showed the C6000 error code.
          Any ideas?
          • cm79
            • 20
            Re: Kyocera KM-5035
            Any ideas?
            Replace Fixing unit.
            • kkendric
              • 301
              Re: Kyocera KM-5035
              Fuser error, reset fuser error and fuser error comes back. what do I do now? Look for a different line of work. Come on, it doesn't take a lot of common sense to follow this one through.
              • NeoMatrix
                Senior Tech.
                • 3513
                Re: Kyocera KM-5035
                Any ideas?
                .......o0.
                You could reset the thermo-stat/sw inside the Fuser case to get it going for about 1 week more, BUT there is a good chance you need a new $600+(Aud) fuser ass'y.
                • subaro
                  • Oct 2010
                  • 1274
                  Re: Kyocera KM-5035
                  kkendric
                  Re: Kyocera KM-5035
                  [QUOTE=NeoMatrix;487570].......o0.
                  Ok Neo, you need to give this guy a more detail description on how to do this, because according to kkendric, he should
                  I think first, he should remove the fuser and use his multimeter and check for continuity on the lamp and thermostat. 99% its the thermostat and if he has old fuser he can replace it with it. 3035-4035-5035 use the same fuser unit. Nobody want to do the simple checks anymore, but rely on
                    • 23009
                    Re: Kyocera KM-5035
                    I could have diagnosed a fuser circuit on my first day as a tech, never having seen one before. I hope this gentleman is just very green. =^..^=
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Re: Kyocera KM-5035
                      I like this guys enthusiasm he appears to have the necessary attitude to make a good Tech...
                      It's the old adage though --"if you give a man a fish you feed him only once".
                      I believe the forum is showing PCTECHMECHANIC where the fishing rod tools are,
                      he just has to go out an catch his own fish to earn the title of Pro Angler.
                      The forum has shown PCTECHMECHANIC the right direction.
                      I feel we shouldn't be holding his hand if his going to be a Tech -- PC,Printer,Copier or otherwise.
                      Welcome to deep water training school 101....
                      Hint: None of us ever stop learning. It's part of a Tech's job way-of-life.
                      • Junior Cyrix
                        Re: Kyocera KM-5035
                        You should replace whole fixing assembly.
                        • Scott
                          • 196
                          Re: Kyocera KM-5035
                          good luck finding one Kyocera quit supporting them about 3 years ago
                          • CWP
                            • Jun 2013
                            • 168
                            Re: Kyocera KM-5035
                            I'm just trying like heck to figure out why you are trying to help on an issue that was posted over 2 years ago. Do you think this still may be an unresolved issue?
                            • Scott
                              • 196
                              Re: Kyocera KM-5035
                              WOW your right, wonder why it is only 7 comments down on the Kyocera discussions?
