KM-5050i LCF PF-750 registering paper size as A4 not letter
  • ultimateprintsolutions
    • Jul 2008
    • 34
    I usually work on HP printer/mfp's, but I have a customer that has a KM-5050i with LCF PF-750 and it is registering paper size as A4 not letter. Everything looks normal, trying to find out if there is a switch that registers size in the feeder assy? Or is it in the settings somewhere? Any help would be appreciated.
  • wragsdale
    • Jul 2014
    • 188
    Re: KM-5050i LCF PF-750 registering paper size as A4 not letter
    If you go into your cassette settings, you should find that the paper size is set to either A4 or Auto (Metric). You can change it to Auto (Inch) or Letter.
    The PF-750 actually has front and rear adjusters to accomodate A4/LTR as well as center adjust, but there are no sensors associated with them.
      • 22981
      Take a look at simulation U208. (Pg 94 of the PF750 service manual). =^..^=
        • Jul 2008
        • 34
        Thanks I will check out both suggestions when i go back with the tray1 lift motor that blew out.
