olivetti
  • edpianix
    • 30
    [Error Code] olivetti
    i have been using olivetti d-copia 2500 for quite some months. just now got an error 180. i try to reset but nothing happen. after i turn it on, the same error come again and again.
    I need your help.
    God bless
  • subaro
    • Oct 2010
    • 1274
    Re: olivetti
    what is the exact message on the screen. don't think it will just be 180 . read what's on the screen and post exactly.
    This machine looks like a kyocera falcon3 engine. not sure though
      • 23003
      Re: olivetti
      This looks like a Stratos to me. If that's the case, your C0180 error message means that the serial number stored on the engine and main controller do not match. The only way this can happen, is if a person were to swap out boards, and not swap back in the original firmware DIMM(s). Only a tech can create this problem. =^..^=
      • copycoan
        • Sep 2012
        • 31
        Re: olivetti
        try u004 if not you can replace eeprom with a blank one and u004 may work, if not can try format hd otherwise pwb or dimm etc...
