Kyocera FS C2526 MFP
  • tcypy1961
    • 773
    Is it possible to copy a test pattern in the individual main colors? Such a copy only in cyan, or magenta, or yellow. If it is possible, how do I do it? Thank you for any help given.
    • 23009
    Re: Kyocera FS C2526 MFP
    You could do a U410 half tone adjustment. That will give you the basic 4 colors.
    Or you could just print any one of these:
    Would any of these help?:
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      The test page from the service menu under system settings does them on one sheet. You could use Blackcat's test pages, or if these have single color in copy mode, just do a sky shot.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • subaro
        • Oct 2010
        • 1274
        I may want to be inquisitive here and ask, why he want to do that. I am thinking he may have some quality drum dev issues and want to eliminate the other colours hardware. If this is the case, then the test print from the service menu would produce the 4 colours. cyan +yellow= green. password for the fs-2626 is 2600, not sure for this model.
        Also older firmware does not have some of the maintence mode items, you must upgrade to the latest f/w to get the additional items [410] as blackcat mentioned and more 21 ect. If troubleshooting is not what you are after, then just ignore me.
        I did two mod kits a few weeks ago and i can put that thing back without a hitch. You must have lots of patience to work on this machine or you may be putting a few lines on what's the stress level thread.
