FS-4020DN, charger roller lines.
  • Hansoon
    • Sep 2007
    • 3385
    The charge roller in the picture of this FS-4020DN was installed at 630K, now at 669K it already developed again heavy lines which are making streaks on the prints.
    A complete maintenance kit MK-360 was installed at 457K. The drum only has been replaced later on again at 580K because of a little nick but the new one still looks OK for now. As said, also the charge roller had to be replaced early because of lines with 630K and develops now with 669K again those lines.
    Question: What can cause this reoccurring premature failure at only 39K of the charge roller and how to correct it?
    Hans
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: FS-4020DN, charger roller lines.
    A clean damp cloth and a bit of elbow grease, should clean the charge roller back to normal operation.
      Ref. No. 2F8-0034(9043)
      < Measures against black spots and black streaks: New distinguishing method (Change of the CASE MC) After
      the stock of old parts is used up>
      FS-2000D, FS-3900DN, FS-4000DN, FS-6950DN, FS-2020D, FS-3920DN, FS-4020DN, FS-6970DN
      Topic
      The print image failures (black spots and black streaks) occurred in the field since the adhesive for the MC roller
      peeled off and the rubber of the MC roller was removed. As the measures, the adhesive was changed to non
      chlorine type in order to improve the durability. (Please refer to the Service Bulletin No.8929_COM-0153_SB.)
      * Due to the change of adhesive material for the MC unit, a projection was added to the CASE MC so that the
      product with countermeasures can be distinguished. Black marking is applied to the CASE MC until the product
      with this projection will be introduced.
      The part code is not changed.
      Although it doesnt look like the rubber is removed like they say
      • Hansoon
        • Sep 2007
        • 3385
        Thanks guys. Besides the elbow grease (must have somewhere still a pot of it) the clean cloth should be dampened with water only, isn't it?
        Hans
          • 23008
          Hans
          Correct.
          Kyocera has taken several tries at getting those charge roller to last on a lot of different models. Voyager, VoyagerE, Saturn, Alphard I, Alphard II all do the same thing. The only trend I noticed is that at higher volumes, you can get more prints before it happens. =^..^=
          • allan
            RTFM!!
            • 5462
            On the panasonic and ricoh machines i found washing the roller under running water with a clean cloth works well. Worked fine on the canon rollers as well.
            Whatever
            • subaro
              • Oct 2010
              • 1274
              cleaning the charge roller with water alone does not do a proper job. paper dust and crust that accumulates on the rollers need a bit of detergent to loosen the dirt to clean the roller properly. simple green all purpose cleaner diluted or even diswashing liquid diluted does a good job. to make fast work of it, i use a used word green scoring pad that has lost its grits with the dishwasing liquid and it does a good job. just don't press hard, let the detergergent do the work. done hundreds of these no problem. just make sure the roller is dry when done and if you are cleaning wth the roller not removed then make sure liquid does not get to the cleaning brush on the assy.
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1887
                I've always cleaned them with alcohol or Blow Off rubber rejuvenator and have never had a problem.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • JVergin
                  Service Tech / IT Rep
                  • 216
                  we use simple green and immediately wipe with the dry part of the cloth afterwards. cuts through the buildup quickly and we haven't had an issue yet.
                  • Hansoon
                    • Sep 2007
                    • 3385
                    I used Windex together with a coarse cotton cloth. Worked perfectly.
                    Thanks for your input guys.
                    Hans
                      • 23008
                      While you're cleaning watch out for lumps. When your charge roller gets lumpy it will not make even contact with the drum, and will start discharging in the innovative spider pattern at 38mm intervals. Occasionally you can get the roller clean enough in the short term, but it will start discharging to the drum from the high spots after a very short period of time.
                      Oh, Happy Halloween! =^..^=
                      • subaro
                        • Oct 2010
                        • 1274
                        One more thing i do with those rollers is i usually remove it and clean it, dry it ,and then reinstall. now when you remove it from the horzontal position it 95 percent will break the bushing. so i put a bit of grease on the shaft and turn a bit and pry it out from the end side of the roller and it slips out easily. then i could also check the cleaning brush that sits below the roller for debris.
