CS 4501 that is dropping toner on the page.
  • Scottb
    • Apr 2013
    • 303
    I have a machine that appears to be dropping toner on the page. I have cleaned all of the guides and filters like on the 4500 series, I have also replaced both the drum and developer units. I also took out the feed unit and cleaned them and with canned air blew out the paper path. I still have this problem and am stuck. 20151007145218.pdf
  • Jessetech
    • Mar 2014
    • 38
    Re: CS 4501 that is dropping toner on the page.
    looks like a transfer problem look at 1st and 2nd transfers also stop the copy in the middle of job
    • Kyo fan
      • Dec 2013
      • 368
      You need to update firmware to the latest (04.05.0010) version that has engine update for toner powder leaking from developer unit.
      • Scottb
        • Apr 2013
        • 303
        Yep sorry about that I did update the firmware, but it appears I didnt use the latest version. I will give it a go and report back.
        • Scottb
          • Apr 2013
          • 303
          Ok sorry for the late update.
          After the latest firmware was installed it still was dropping toner. Somehow I had thought, that I had already removed the reg roller assy, but no I didnt. This was where all the toner was dropping from. I cleaned the assy and the rail, that is underneath, and that has seemed to fix the problem.
          I have been waiting for a few weeks just to make sure the problem was fixed for sure.
          Thanks all for the help.
          Scott
            • 22934
            I just came across this the other day on a 3500i. The paper dust collector was packed full, but not paper dust. It was toner. And yes, vacuuming did the trick. =^..^=
