Zeus Feed Rollers
    • 22997
    Zeus Feed Rollers
    I just happened to notice today that 302K906370/302K906350/302K06360 feed rollers for the KM-6500i/8000i are the same exact identical size as Konica Minolta's A00J 5636 00, and A5C1 5622 00.
    Has anybody tried subbing in the KM (Konica Minolta) rollers into the KM (Kyocera Mita)? Even the rubber only transfer to the other hubs. I've got a couple Kyoceras getting 150K and less from the OEM rubber.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: Zeus Feed Rollers
    bumping this, I'd like to know if there are viable substitution as well.
    How is the cost vs known life span on those rollers?
    Idling colour developers are not healthy developers.
      • 22997
      The KM pickup is $15 more. The feed and sep are $1 more each. ~50% more expensive, but a savings if it will double the yield (and the associated saved labor). =^..^=
      • Hansoon
        • Sep 2007
        • 3374
        Cat I used them a few month's ago for two FS4200DN printers to replace roller 302HS94032. Both machines made 60K until now without any problems.
        Hans
        • GUNit
          • Jan 2008
          • 23
          Hans
          Been doing this for a while now with great success. the neoprene compound works so much better on the Kyoceras. use them wherever you can from printers to small mfps to the 8000is. on some they just fit straight on on others you can just fit the roller without the core but yes they work great. have mentioned this to the Kyocera rep and they cant be seen to be using the Konica design. the only thing is there are lots of other problems in and around task alfa feed heads these days for instance they cant seem to get the separation tension right and that has an impact on roller life but yes fitting the Konica rollers is the way forward for sure.
            • 22997
            Thanks GUNit. I was hoping for that response. =^..^=
            • JR2ALTA
              • Feb 2010
              • 2030
              Ah yes they are the same.
              My first opinion over 3 years ago was that Kyocera had the superior roller.
              http://www.copytechnet.com/forums/th...konica+jr2alta
              But then the Red Rollers came out so I alerted the forum that they were pretty universal and very superior.
              http://www.copytechnet.com/forums/ko...konica+rollers
              And an added update. The Red Rubber is the same same as practically all Konica ADF Rollers. Remove rubber, spray some Windex to the hub and she'll slide right on.
              • ZOOTECH
                Senior member of CRS
                • 3375
                Whoa, waaay too much info.
                  • 22997
                  ... Remove rubber, spray some Windex to the hub and she'll slide right on.
                  Or use your roller press (yesterday's project):
                  3 1/2" of 1" copper.
                  Left cap drilled with 8mm hole.
                  Right cap drilled with 14mm hole, to accommodate the roller hub.
                  Temporarily assemble bronze bushing to left cap with 8mm x 24mm bolt and nut.
                  Assemble left cap, copper tube, right cap, then solder 3 joints. Let cool.
                  Cut away center part of the tube with Dremel cutter wheel, 45mm long by 1/2 the circumference
                  Remove the bolt, wash away any remaining rosin and clean up rough edges.
                  8mm shaft, 5 5/8" long. The end at the roller milled down to 6mm, 3/32" long.
                  It's hard to see, but there is a 4mm wide groove lengthwise, 20mm long, 2mm deep; to accommodate the plastic snap on the KM-8001i rollers.
                  Handle of your choosing, preferably with a smooth palm surface, pinned to the shaft and epoxied.
                  Post your picture, or better yet an improvement. I tend to over-build. You know, the ten dancing elephants test.
                  • allan
                    RTFM!!
                    • 5462
                    Then the grey ribbed roller will work on the pick-up as well and they are half the price of the orange ones.
                    Whatever
                    • NeoMatrix
                      Senior Tech.
                      • 3514
                      [ATTACH=CONFIG]30979[/ATTACH]
                      Okay I'll bite.
                      I have a feeling I shouldn't ask this.
                      What is the ten dancing elephants test ?
                        • 22997
                        Okay I'll bite.
                        For as long as I can remember (OK, quite a bit longer than that) I have always built things to withstand the stresses provided by 10 dancing elephants. I do not recall exactly who defined that particular standard, but everyone I know seems to understand it. As a result, many of the things I build are considerably heavier than need be, but rarely break.
                        Real dancing elephants are quite rare, so I don't usually get to truly field test my constructions. It's so difficult to assemble 10 of them in one place. =^..^=
                        • NeoMatrix
                          Senior Tech.
                          • 3514
                          [ATTACH=CONFIG]30977[/ATTACH]
                          [ATTACH=CONFIG]30978[/ATTACH]
                          I like the above rubber roller press idea. I might have to put one of these together.
                          It should also work in reverse and remove the old rubber roller as well.
                          Put a metal cylinder inside the main tube with an inner diameter just big enough for the plastic housing, and the push the old rubber roller off the plastic housing. Viola!!!.
                          The inner cylinder need not be full length of the main outer tubing, it just needs be a simple thin ring shape of metal soldered into place inside the main tube. Put a blanking plate/metal washer over the top of inner removal cylinder and press the new rubber roller onto the old housing, as per normal.
                          With a bit of cheeky modification to the design it might be possible to do it in one operation....
                          See attached image.
                          I just had a light bulb moment. The roller press can be done even simpler and smaller to fit in a work bag. I'll leave it for the time being. It would be interesting to see how many others pick up on the general idea.
                            • 22997
                            Not only can you remove rubber from both the old and new rollers for swapping hubs, but if you start the rubber and turn it around in the press, it will install the rubber onto the hub too. Pictures please. =^..^=
                            • Hansoon
                              • Sep 2007
                              • 3374
                              Pure bare ingenuity here guys
                              Cool ideas!
                              Hans
