Kyocera M6526cdm Scan to Email
  • kmtech
    • Sep 2008
    • 125
    Hi All, I am setting up this M6526cdm to scan to email, trying to use Comcast server settings, tried every setting i could find for the server no luck. Has anyone set this machine up to scan to email using comcast? if so wondering which settings to go with. scan to folder is working..
    Thanks in advance
    Bill
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera M6526cdm Scan to Email
    First make sure the machine can go out by entering proper dns and domain (if there's one) under network settings. Also go to protocols section and check if SMTP is on, and under it put SMTP security to SSL/TLS. Comcast no longer supports port 25 for security reasons so your settings would be:
    SMTP Server Name: smtp.comcast.net
    SMTP Port Number: 587
    SMTP Server Timeout: 60
    Authentication Protocol: On
    Authentication as: Other
    Login Username: youremail@comcast.net
    Login Password: your password
    Scroll down, and under E-mail Send Settings, put some email adress as sender address. Dont forget to hit Submit.
    • kmtech
      • Sep 2008
      • 125
      Funny, I noticed it tested ok on the web, but when i go to the machine I get a 1106 Error..
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        1106 says there's no email address in the sender field.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
