Kyocera Mita KM-2550
  • tcypy1961
    • 773
    What would cause a shadow on the backside of the copy? It is a 1/4 of the page, from the lead edge. If I make multiple copies it is only on the first copy. Could it be that the transfer roller is bad? If so, what does it involve removing the transfer roller? Thank you for any help given.
    • 23010
    Re: Kyocera Mita KM-2550
    Are you using OEM toner? Is there any evidence of primary grid discharge? I'd put the highest likelihood on primary charge loss. =^..^=
    • Kyo fan
      • Dec 2013
      • 368
      If you have it on the internal printouts, you should also have the light gray background across entire front page. In that case it's poor quality non-oem toner.
      • copydocinc
        • Mar 2015
        • 263
        To replace the transfer roller, you must first remove the duplex unit to access the backside of the transfer rollers holder screws and what not.
        I have once, had the same issue you are experiencing and replacing the transfer roller was the fix.
        I'm not saying that non oem toner is not to blame, but I have had all my customers with this model using non oem toner and really have had no
        problems to speak of, because of it.
