kyocera mita fs-1018 mfp Arkadaşlar ben forum yeni katıldım C-6400 error arızası var.,yardımcı olursanız sevinirim
acil kyocera mita fs-1018 mfp
milarioan
just reset the fuser code with sim 163
i think here is the solution,
http://www.copytechnet.com/forums/ky...ror-codes.html
Here's the real way to reset that fuser code.
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Hope this helps you
i have that error in the past and that procedure works.
regardsLast edited by Guest; 08-30-2008, 06:58 PM. -
