twain scan
  • CrapAimer
    • 296
    twain scan
    Hi All
    Trying to set up a 2551ci with twain scan using windows fax and scan ? any pointers much appreciated
    George
    • 23009
    Re: twain scan
    I had trouble setting up a FalconII once with TWAIN. I just would not function. To test out the scanner NIC I installed the ScanFile Utility to FTP scan. It worked and scanned properly. Then TWAIN worked too. I don't know why. Then I removed the ScanFile Utility and TWAIN stopped working.
    I left that customer with the ScanFile Utility installed and running, and not programmed for anything, just so TWAIN would work. I don't have any kind of explanation for it. =^..^=
    • CrapAimer
      • 296
      Re: twain scan
      sorry but where do i find the scan file utility ?
      George
        • 23009
        Re: twain scan
        This is not a Kyocera supported website, so click on this link at your own risk:
        403 Forbidden
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          Re: twain scan
          Download Center - KYOCERA Document Solutions America
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • qbert69
            • Mar 2013
            • 1152
            Re: twain scan
            Network TWAIN or USB TWAIN???
            There may be a security protocol on the machine that needs to be set, especially if it is the network TWAIN.
            Also--If you are using a special TWAIN hosting software, make sure in your security software (if you have any installed--AVG is a PITA!) that you have made an exception for all network connections for your scanning software!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
