FS-3920DN FS-4020DN Command Center password reset
  • kyove
    • Apr 2015
    • 62
    Hi Folks,
    I finally find the procedure to reset command center password on FS-3920DN and FS-4020DN (and probably other printers).
    I found many thread about this argument but no one has the solution so I'm going to post it here.
    Follow these steps:
    1. On printer panel Menu > Security > Security Level > Low
    2. Send this Prescribe command to the printer (ftp, lpt, Kyocera Net Viewer, IC Link, makes no difference)
      !R! KSUS "AUIO", "CUSTOM:Admin Password = 'admin00'"; EXIT;
    3. Open your browser and access command center with default password "admin00".
    I hope it can be useful for someone, it really takes a lot of time to find this solution.
    Have a nice day guys,
    Kyove
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: FS-3920DN FS-4020DN Command Center password reset
    Originally posted by kyove
    Hi Folks,
    Follow these steps:
    Kyove
    I can empathise with your adulation.
    It feels darn good to find the solution to a p!ss-me-off-problem....
      • 22997
      Congratulations! =^..^=
      • bigfacedboy
        • Jun 2016
        • 5
        Hi Folks,
        Follow these steps:
        Kyove
        MASSIVE thumbs-up. Thanks. (o:
        • subaro
          • Oct 2010
          • 1274
          Hi Folks,
          Follow these steps:
          Kyove
          Tried everything before and nothing worked. Tried this on a fs-1135 and it works. Only thing, when a settings is made, make sure to switch off and on the machine for the settings to take effect, even after when you send the command. Don't forget to switch back the security level settings to high.
          THE BOMB.
          • bigfacedboy
            • Jun 2016
            • 5
            I've found that this works on many models but in some cases (e.g. fs-c5350) you need to use Kyocera Net viewer rather than using ftp.
            R click on printer> select communication settings>set login id & pw (3000, 3000 on fs-c5350).
            Close comm. settings window, r click printer>advanced>TCP/IP send data. In the "text" box, input the command as above (!R! KSUS "AUIO", etc.) and send the command.
            (You may need to set the security setting to low via the printer's security menu).
            • Maher
              • Oct 2016
              • 15
              Just to make sure , the command is
              Correct ???
              • bigfacedboy
                • Jun 2016
                • 5
                Correct.
                Correct ???
