P2135dn emergency firmware?
  • jam-o-matic
    • Oct 2012
    • 72
    [Dead] P2135dn emergency firmware?
    has anyone been able to recover a machine (firmware update interrupted) using the Emergency Firmware procedure? I have done it on a larger TA machine & was hoping it was just as straightforward on this little printer, but no joy using USB or the SD card slot directly on board.
    thanks in advance!!
    • 23008
    Re: P2135dn emergency firmware?
    Did you format the SD card on a functioning P2135 printer, then place the extracted firmware on the root of the card? I would consider that your best chance of success. =^..^=
    • jam-o-matic
      • Oct 2012
      • 72
      No, i formatted thru laptop - tried both FAT & FAT32. This is a great idea, will try next!
        • 23008
        The printer will set up a folder structure that is necessary. The hard part is finding a working machine to format the card, since a dead machine can't. =^..^=
        • jam-o-matic
          • Oct 2012
          • 72
          can i find the format instructions in the manual? haven't done this before!
            • 23008
            It's in the service manual. It's quite simple though. In most cases you just insert the unformatted card into the SD slot. The machine recognizes it, then asks you if you want to format the card. There is also a function in the system menu to format an SD card. The last machine that I still regularly used SD cards was the KM-420i, and maybe the Saturn. The menu may have been re-organized since then. Just search: format SD card and you should find what you need. =^..^=
