Reset Admin password
  • luis8832
    • Dec 2008
    • 250
    [Misc] Reset Admin password
    I have a fs-1135 mfp, in the office it was in someone changed the admin password to logon to the command center. I have read about some prescribe commands that can work but i am not to savvy on prescribe and i am learning km-net viewer and ic-link. Any information or knowledge will be greatly appreciated to all in advance.
  • jhalfhide
    • Apr 2015
    • 451
    Re: Reset Admin password
    Kyocera have a prescribe manual available somewhere online. Basically type the prescribe command into notepad and save it. Then FTP to the machine's IP and drop the file there. That's it.
    • subaro
      • Oct 2010
      • 1274
      So does anyone have a solution to reset the command center password. So far nothing seem to work except for kyocera to remote in and do it, which is time consming and only if you have kyocera dealership of course. any one with a proven prescribe command. machine that has u21 will clear it, but also clear other machine settings.
      this machine does not have u21.
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5806
        Originally posted by kyocera.team
        its prescribe language the easy way to do that is
        first of all you should use KX driver
        -printer properties
        -device setting
        -PDL (use PCL5e )
        then open new word file and select prescribe font and type
        !R! EGRE; EXIT; this is for command center
        it will solve your problem good luck
        save the file as reset.txt
        Originally posted by Skynet
        Open cmd and cd to the directory where you saved reset.txt and in the cmd prompt type the following
        ftp ***.***.***.***
        ***.***.***.*** = ip address of printer
        Next press the enter key twice (no password required)
        Next type put reset.txt and press enter
        hope this helps.
