TA 250/300ci not passing the grey adjustment
  • cdvidaceiba
    • 80
    i got several taskalfa 250/300ci that doesnt pass the grey adjust , when i try to scan the pattern No. 1 just say " cannot perform grey adjust plese check the original" i check the original and cannot pass form that point
    any ideas???
    thanks in advance
    sorry for muy english ...
  • jhalfhide
    • Apr 2015
    • 454
    Re: TA 250/300ci not passing the grey adjustment
    The original must either be too poor quality, or the glass and mirrors need a check and clean.
    • cdvidaceiba
      • 80
      thanks for your help i send photos of the pattern20160303_062522.jpg20160303_062529.jpg20160303_062533.jpg
      i already installed most recent firmware i got , clean the mirrors , drum refresh , developer refresh , color calibration
      machinne got 591k
      • jhalfhide
        • Apr 2015
        • 454
        That machine needs parts. The white lines and faint image quality all need fixing before you do the gray adjust.
        • cdvidaceiba
          • 80
          i will try cleaning the drums and the transfer unit .
          what parts you think the machinee needs???
          • jhalfhide
            • Apr 2015
            • 454
            Difficult to tell from those prints as they don't show the coverage well enough. Print some sky shots of each colour and we'll look at those. Definitely looks like you have poor black though
            • cdvidaceiba
              • 80
              Thanks i will try changing the black unit . I will let you know the result
              I really apreciate your help
              • Reed
                • Feb 2011
                • 258
                Replacing the parts,developer unit (s) should definitely help. I have had the same problem with a few of these units as well. Sometimes it has been corrected by performing the AC adjustment, drum refresh and developer refresh, developer calibration. I had to perform them each several times. The print quality improved and the machine was able to perform the auto gray adjust successfully
                • tmaged
                  Owner/Service Manager
                  • Oct 2008
                  • 1888
                  If you've cleaned everything really well, it will need both maintenance kits. The developer oxidizes & doesn't carry enough toner to keep the density dark. Those are way to light to pass, the machine isn't seeing what it should.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • Kyo fan
                    • Dec 2013
                    • 368
                    To be able to complete it, optics have to be clean, but more important - colors have to be aligned. Execute Color Calibration, following Color Registration and align them properly. Than it should work.
                    • geordie40
                      • Jan 2012
                      • 6
                      Its definitely the black thats causing the issue, replace black drum and dev and problem solved, a quick "cheat" is to get a black marker and colour in the black rectangles in the corner of the pages as thats what it looks at to start the process, if it cant see the rectangles it fails straight away.
