FS-4300DN Prompting for new toner
  • shtrouble
    • Apr 2013
    • 31
    Hi, Got a problem with FS-4300DN. Firstly printing blank pages. Replaced developer unit and drum. Kept prompting for new toner even new toner was put it. Any ideas? Thanks
    • 23009
    Re: FS-4300DN Prompting for new toner
    Perchance, did you follow the instructions that came in the box with the developing unit? I'm thinking probably not.
    You see this printer uses monocomponent toner, like many of the other Kyoceras, so the developing unit arrives completely empty. There are simulations that you must run to fill the developing unit. Did you save the destructions? =^..^=
    • Has Been
      • Nov 2012
      • 48
      Mark the mag roller to ensure that it is turning.
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        I'm with big cat on this one,
        It happened to me in the past, I installed a new imaging unit to a Kyocera printer and the machine kept asking for toner even though the toner cart was perfectly fitted.
        Happens that the unit dind't have enough toner in the dv chamber because when new, they arrive completely empty.
        -You need to run a simm to pump up enough toner to it - *I can't remember which one now*
        OR as I did, add it manually to the DV unit, then close it and put the now-almost-empty toner cart in its place, and start the machine again, and that's it.
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • subaro
          • Oct 2010
          • 1274
          from the sm
          Initializing the developing unit (toner install mode)
          Description
          The new developing unit is shipped from the factory with no toner contained. The developing
          unit can be automatically replete with toner when a toner container is installed onto
          it and the printer is turned on. However, because the toner reservoir in the developing
          unit has a large capacity, it requires a lengthy period of time until a substantial amount of
          toner has been fed to get the printer ready. (A new developing unit needs approximately
          200 g for triggering the sensor inside.)
          Purpose
          To execute when the developing unit has been replaced.
          Method
          1. Enter the Service Setting menu.
          2. Select [New Developer] using the cursor up/down keys.
          3. Press the OK key.
          4. Select the [YES] using the left select key.
          [Accepted] is displayed.
          The toner installation is performed when power is turned on and off.
          NOTE: Toner supply is stopped when toner installation mode is performing.
          • JR2ALTA
            • Feb 2010
            • 2033
            It will take ten minutes more or less, so don't panic
            • shtrouble
              • Apr 2013
              • 31
              Thanks Subaro. Selecting New Developer fixed that problem.
              However, it is printing blank pages. A quarter of the developer roller has very light coat of toner, the rest is still silver in color. Even the part cover with toner, nothing prints on the page. I increased the density and very faint print of the Kyocera logo when printing the status page and subsequently nothing on any pages. The faint print means the laser shutter is opened. Any ideas
              Thanking you
              • subaro
                • Oct 2010
                • 1274
                Thanking you
                Then toner is not being fed from the toner cartridge to the dev housing. examine the toner cartridge blue lever and see if is not damaged. Have found a few with not adding toner problem. If the mag roller is not fully covered with toner , then you have a problem with toner not getting there. had one case where the gear that drive the toner cartridge on the right side of the dev unit was out of position. all in all your dev unit has a problem i would suggest.
                another thought, try a new or used toner cartidge. also pull out the dev unit and move the blue toner lever back and forth and observe if is acutually moving the mechanism on the dev toner dispense hole.
                • Kyo fan
                  • Dec 2013
                  • 368
                  Replace the developer clutch. It's a well known issue with entire series, and there's a specific bulletin on it.
                  • subaro
                    • Oct 2010
                    • 1274
                    Dev clutch. really, never had to replace one on this series. i replaced the bypass clutch once and that machine had been in a cement factory, lots of dust. Anyway troubleshooting the dev rotation is to mark the gear that the dev clutch is driving and also the dev roller one side . fuser seem to be the most common problem and a few with toner augur problems. besides that they run solid and we got lots of these on the field getting up in to over 100k-200k.
                    • shtrouble
                      • Apr 2013
                      • 31
                      Thanks Subaro. Toner level is working fine. It has to be the Dev Unit.
                      • shtrouble
                        • Apr 2013
                        • 31
                        Good suggestion Subaro. I marked the dev roller and the gear on the transfer roller. They did not move! I'll check the Dev Clutch as suggested by Kyo fan, thank you both.
