Keep getting error code F234
  • punkinhead
    • Jan 2016
    • 3
    [Error Code] Keep getting error code F234
    customer running large job through doc feeder and half way through error pops up and deletes the job, anyone seen this lately thanks
  • Woody214
    • Oct 2015
    • 29
    Re: Keep getting error code F234
    What model machine is this?
      • 23008
      An error is detected at the Image processing section. DDR2 memory check. A certain part of the memory may be faulty. The frequency of failure occurrence is dependent on the frequency of access to the faulty bit. The ASIC may be faulty if the memory is not.
      1) Reseat or repl DDR2 memory: YS1 & YS2; 2) Reformat HDD U024 FULL; 3) Initialize backup memory U021; 4) Repl main PWB; 5) Repl HDD; 6) Retrieve USBLOG and contact SAD.
      • subaro
        • Oct 2010
        • 1274
        There was two tickets with this code on the q and a site, and both fixes pointed to the adf harness replacment. [ Taskalfa models ] There are no bulletins as i can see thus far.
        • subaro
          • Oct 2010
          • 1274
          Without the model of the machine, it's ducks we will be shooting at. please reply with the model number . It is the proverbial " doc i have pain " , the doc cut out the right foot when later he found out it was the left foot. the motive [lack of proper information ]
          • Smodd
            • Jun 2016
            • 2
            Any new info on this? I have a 3501 with F234 & F214
            • Assaf
              • Jun 2009
              • 59
              Update the firmware will takecare of this issue. The machine read certain files as corrupted data and throw these codes.
              • qtech
                • Jul 2009
                • 41
                Greetings all,
                Not to dredge up an old thread, but I've got a 3051ci (166K) with this same issue. 0640 code (HDD) a week ago, so I replaced with a known working. U024 and U021 to no avail. Replaced the DDR2's with known working. FW update performed. I can print internal reports with no problem and customer can print to it fine. When copying from glass or DP, paper stops at Reg Roller, then jam and F214 or F234, so it's an image scan issue.
                Sheesh, any further advice other than main pwb?
                Thanks much,
                Chris
                • PrintWhisperer
                  • Feb 2018
                  • 472
                  Check/reseat/replace DP relay PWB (mounted to MAIN PWB) and red SATA cable. Also possible ISC PWB problem (other end of SATA cable).
                  "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
