3501i Color scans are wrong color
  • jimtanner
    • Apr 2014
    • 5
    [CQ] 3501i Color scans are wrong color
    When the customer scans a yellow invoice from the glass it is perfect color. When they scan it from the doc feed the color is pink
  • Ropariva
    • 693
    Re: 3501i Color scans are wrong color
    Sounds like you will need to run the special Kyocera scanner set up test charts through. This should correct your colour issue.
    • qbert69
      • Mar 2013
      • 1152
      ....just tell 'em "You're FIRED!!!"
      and give 'em the "PINK SLIP"!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • jimtanner
        • Apr 2014
        • 5
        I ordered them and should have them today. Thanks
