Ta 255 main charge roller. getting bumpy
  • Gar the pilot
    • Aug 2025
    I have a client with a Ta 255 that has a bumpy main charge roller, PN 302K393140 PM kit MC-457. Are these aval?? my parts guy just got me a new drum unit. Has any one else seen these go bad like this??
    I have 2 more, lease returned, TA 305's to remarket and one of them has a bad roller also. just hate to waste a drum over a charge roller.
    Thank You
    Gar the Pilot
    flying weather is back!
  • Centvrion6
    Re: Ta 255 main charge roller. getting bumpy
    Charge rollers go bad, get lumpy and little fairy rings on them. Just replace the roller and save the drum.
    • JR2ALTA
      • Feb 2010
      • 2033
      It is bizarre
        • 23009
        It started with the Alphard series. On Voyager and Saturn you would get the typical ozone buildup on the surface, but they did not go lumpy. Alphard I and AlphardII get lumps that discharge, sometimes in that interesting spider pattern. Once it's lumpy it will continue to discharge in the same areas, at the high spots. I don't understand why Kyocera cannot design a charge roller to last.
        MC-475: 302K393141
        • Woody214
          • Oct 2015
          • 29
          SOS different day on the 3010i and 6525/6530. Never saw this on FS 3140 series, as you could clean them till the cows came home and they would always look like new.
          Seems to be a softer or less durable material that these newer ones are made from, and at 70- 80 bucks a pop they are not cheap either...
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            We always just replace the whole drum unit and keep the old drum as a spare if need be. The cost difference between the entire drum unit and the charge roller is only like 15-20 dollars.
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • Gar the pilot
              I will replace the drum unit and keep this old one as backup. Kyocera can be so good,..and then be bad about simple things. My DC 111 finially retired with the Business owners who retired and sold the business,..A TV / appliance shop. It was still making good copies. That quality was my introduction to Mita.
              I had started Sharps
              Gar The Pilots
              • copygal
                • Feb 2012
                • 23
                Gar The Pilots
                Mita DC-111, Best small copier ever made. I still have one in a home office...34 year now.
                  • 23009
                  I worked on a lot of those. Shimming the tabletop clutches was quite an art. Anybody remember the rubber stopper breaking off? When you clammed the machine open the glass would slide all the way over, off the rails and skate across the floor. It was quite a surprise the first few times. =^..^=
                  • Geo
                    • 662
                    You learn very quickly to anticipate this little surprise. I don't know if Mita had a fix , but Gestetner did for the broken stopper.
