300ci light on copies, prints OK
  • olliesps
    • Jul 2025
    Looks like eco mode however when enabled on printer there is a difference but not on copy mode. Replaced CCD/CIS almost all PWBs except Power Supply. Problem fixed running U21(memory clear.)
  • Synthohol
    Certified Konica Expert
    • 5832
    Re: 300ci light on copies, prints OK
    have you run a detailed gray adjustment?
    Press the System Menu key.
    2 Press [ ], [Adjustment/Maintenance], [ ] and
    then [Next] of Gray Adjustment.
    3 Press [Detail].
    4 Press [Execute]. A color pattern is printed.
    Check that the number "1" is printed at the bottom
    of the color pattern.
    5 As shown in the illustration, place the printed side
    down on the platen with the three black boxes
    aligned to the top.
    6 Press [Execute]. The color pattern is read and
    adjustment begins.
    7 The second color pattern is printed.
    Check that the number "2" (to "5") is printed at the
    bottom of the color pattern and repeat steps 5 to 7
    four times to read color patterns 2, 3, 4 and 5 in
    sequence.
    8 Press [OK] in the adjustment end confirmation
    screen.
    • olliesps
      Yes. Even went to recalibrating scanner using charts (U425) Nothing worked. Contacted Kyocera - pretty much recommended the steps already taken. Finally no other choice but to give U21 a go and it worked.
      • Synthohol
        • 5832
        Well damn!
        Hope you had all their settings saved.
        Thats one to remember.
