TASKalfa 4550Ci - Diagonal line on prints
  • D Colour
    • Oct 2008
    • 213
    [CQ] TASKalfa 4550Ci - Diagonal line on prints
    Hi
    We have a 4550Ci, which, when on runs starts to give a dirty line running across the prints. The line is not straight, it runs diagonally/deviates across the page. It doesnt appear in the same location on every page. Paper is fed short edge first.
    If you run 8,10 or 15 pages off, its fine, it only shows up on a print run.
    S45C-216052710400.pdf
    Haven't been out to investigate yet, just wondering if anyone has seen this before?
    J
    Everything that has a beginning, has an end.....
  • correo.tony
    • 72
    Re: TASKalfa 4550Ci - Diagonal line on prints
    Hy !
    check de DK-8505K unit for another and confirm if appears the diagonal line, damaged cleaning blade or drum kit ????
    Bye
    • D Colour
      • Oct 2008
      • 213
      Originally posted by correo.tony
      Hy !
      Bye
      Will certainly have a look. But I think if it was drum or blade then the line would be running straight across the page and always in the same position.
      • Alexkyocera
        • Jul 2015
        • 82
        Please check your Fuser Unit to see if the heat roller is damaged. also if there is a built up of toner between the Drum and Developer unit it can cause the that image quailty as well, but it has to be a Consumable Item thats damaged. DK, DV, FK check all.
        • 20gaugeO/U
          • 557
          Or a long human hair wrapped around the charge roller or dev mag roller. Seen that more on the 255/305 models but since your line is moving that's my first thought.
          • LNorris
            • Sep 2008
            • 645
            we had the edge off of a label page wrap around a drum and do something like that
              • 23008
              It doesn't make sense. For these reasons:
              1) If it were scan related like a dirty slit glass, then either the original image would be equally skewed or the anomaly would be straight in the feed direction.
              2) If it were drum related the maximum length of the anomaly would be 126mm. A LTR-R page is 279mm, or an A4-R page is 297mm. A drum related anomaly would give you two full repetitions of the flaw.
              3) If it were a charge roller related issue the maximum length of the anomaly would be 26mm, or 11 repetitions on a LTR-R or A4-R page.
              Here's my guess: Enduser #1 copied a blank original. The paper guides in that tray were set loosely ... let's say 279mm length by 230mm width. The paper skewed. Then enduser #1 examined the "blank" page, and not wanting to waste paper, put it back into the tray face up. Later enduser #2 copies onto that same piece of paper a second time. Personally I think this is a one time thing that you won't be able to repeat.
              • JDR
                • Jan 2015
                • 82
                I already had this cause a paper fiber was stuck to the sleeve roller.
                This caused irregular lines.
                Else blackcat got it.
                • flimmer
                  • Jun 2008
                  • 30
                  I've seen this one time at the 3550ci, hair/dustball in the black develop unit.
