M3550idn jamming in the adf
  • n25an
    • Jul 2008
    • 1030
    M3550IDN JAMMING IN THE ADF
    paper jams as it tries to make the curve to move over the white strip above the slit glass... the section towards the front makes it in but the back section sticks out and jams...
    1. I checked the path... nothing in the path at all no papers no tape... no tabs nothing...
    I took out the for screws holding the adf gears and such down... pulled it out... and pried out the exit section on the bottom... no tape lodged in their...
    the best i can figure... its either a solenoid thats bad that flips for duplex that has gone bad... possibly or it is the whole adf thats twisted or the hinge close to the slit glass has gone bad... the hinge is lose... it does not sit flat...
    I am going to do some research tell me what you guys think I should try next... if I come up with a solution I will let you know...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • copygirl
    • 75
    Re: M3550idn jamming in the adf
    The hinges are just plastic so you've probably got one busted. We've changed several and keep them in stock.
    Ginger
      • 22930
      jam codes? =^..^=
      • n25an
        • Jul 2008
        • 1030
        jam codes? =^..^=
        didn't get one... my apologies... a new adf has been ordered...
        • n25an
          • Jul 2008
          • 1030
          I recommended the hinge but manager went with adf replacement...
          • n25an
            • Jul 2008
            • 1030
            thanks for the hinge catch...
            • Practic
              • Oct 2014
              • 56
              Hi all!
              Got same issue with Ricoh MP 501 (different label, same machine) and with help of college found - that issue was with hinges, same symptoms: clear paper path and paper just can't get curled correctly during movement when it's close to glass.
              Thanks and good luck!
              Sent from Ericsson DBH 1001.
              • JR2ALTA
                • Feb 2010
                • 2028
                Semi-Off Topic
                I would exhaust all resources before assuming a Kyocera solenoid is bad. Kyocera has the least non-consumable failures of any brand.
                • ntbann
                  • Jan 2012
                  • 623
                  Originally posted by JR2ALTA
                  Semi-Off Topic
                  What about Kyo clutches filling with rust?
                  • JR2ALTA
                    • Feb 2010
                    • 2028
                    I said least not zero. Plus those clutch issues aren't "out of the box " bad. Usually high copy count.
                    • wragsdale
                      • Jul 2014
                      • 188
                      main chargers?
                      • JR2ALTA
                        • Feb 2010
                        • 2028
                        Are main chargers "non-consumable" in your world?
                        • BLADE
                          former propeller tester
                          • 478
                          adf hinges ?
