4550Ci Issue printing from MAC (El Capitan)
  • D Colour
    • Oct 2008
    • 216
    [CQ] 4550Ci Issue printing from MAC (El Capitan)
    Hi
    Having a strange problem in a customers, were the prints from the MAC are brutal, in comparison to the Windows 10 PC. They generally use 2 programs when printing, Microsoft Word and Adobe PDF.
    MAC is running OSX 10.11.4 (El Capitan).
    When printed from the MAC using word or as a PDF (created by word). The fonts become bolder and not as sharp as they should be and have a red tinge on the outline. From the PC they are fine.
    Its maybe not easy to see from those scanned files without zooming in. I've taken a photo of a side by side which hopefully shows it better.
    The left side is the MAC.
    And the red tinge round the text....
    Its the latest MAC driver available on Kyocera's site (OS X 10.5 and newer - 3.2, build 11-2014).
    The 4550Ci is on firmware version 08.10.0030. This is slightly older that what is available, but the newer firmware updates don't mention any print quality fixes.We will of course update this, but expect it to make no difference.
    Any suggestions, other that burning the MAC?
    J
    Everything that has a beginning, has an end.....
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: 4550Ci Issue printing from MAC (El Capitan)
    Does the Mac give the print as image option in their version of Reader ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • D Colour
      • Oct 2008
      • 216
      Don't know tmaged, will have a look at that. Not up to speed on the MAC side of things unfortunately.
      Is this an option once you go file and print? To print as an image? Will certainly try this if its available and see.
      • tmaged
        • Oct 2008
        • 1888
        File>print>advanced>Check print as image. This prints the document as a picture rather than lines of text. It's part of the Acrobat software.
        Hope that helps !
        -Tony
        www.dtios.com
        • simonsays
          • Aug 2013
          • 95
          There is a patch that goes with those drivers did you use it
          Originally posted by d colour
          hi
          having a strange problem in a customers, were the prints from the mac are brutal, in comparison to the windows 10 pc. They generally use 2 programs when printing, microsoft word and adobe pdf.
          Mac is running osx 10.11.4 (el capitan).
          When printed from the mac using word or as a pdf (created by word). The fonts become bolder and not as sharp as they should be and have a red tinge on the outline. From the pc they are fine.
          [ATTACH]33272[/ATTACH] [ATTACH]33273[/ATTACH]
          its maybe not easy to see from those scanned files without zooming in. I've taken a photo of a side by side which hopefully shows it better.
          The left side is the mac.
          [ATTACH=CONFIG]33274[/ATTACH]
          and the red tinge round the text....
          [ATTACH=CONFIG]33275[/ATTACH]
          its the latest mac driver available on kyocera's site (os x 10.5 and newer - 3.2, build 11-2014).
          The 4550ci is on firmware version 08.10.0030. This is slightly older that what is available, but the newer firmware updates don't mention any print quality fixes.we will of course update this, but expect it to make no difference.
          Any suggestions, other that burning the mac?
          j
          • D Colour
            • Oct 2008
            • 216
            I don't believe so, where do I find this patch?
