Hi guys
got a machine that is 1.66mil prints causing this jam from tray 3 bulk bin.
the tray is the main tray not sure of volume but would put it close to 1mil?
I changed all the rollers as they were worn and ran 150 from the tray no issue, the jam log showed various gaps in jams 5-10-30 quite close so thought it was fixed as I an lots more and the machine was printing out while I waited but has come back in for jamming, not been there yet as call came in to late today.
im guessing it will be the same and the customer has stopped using the machine, they do have others.
im fishing for anyone who may have had this jam code from any tray?
My thoughts are I will swap paper feed units with one of the less used ones as a tester but if you know of this or a bulletin I would be grateful for your help.
cheers
Les
cheers
Les
