Kyocera M6353cidn - scan defaults
  • kuby
    • Oct 2007
    • 1407
    Guys is there a way to set the scan default so it will come out in portrait instead of landscape when viewed. I can set it and scan and it comes out OK but you have to set it each time. Is there not a default setting you can set so you will not have to do this each time.
    Sorry it is a M6535cidn
    • 23008
    Re: Kyocera M6353cidn - scan defaults
    Are you sure about that model number? That doesn't bring up anything on the Kyocera public site. =^..^=
    • kuby
      • Oct 2007
      • 1407
      Re: Kyocera M6535cidn - scan defaults
      Found the setting...thanks
