Taskalfa 4500i Dead Display
  • Elmo
    • Feb 2010
    • 541
    Hi All
    I have a taskalfa 4500i and a 3500i both machines powers up ok (scanner finds home and motors turn and complete warm up cycle)
    but display is totally dead
    any pointers before i start pulling them apart
    is this a known issue on these machines
    thanks in advance
    I Used To Live To Fix Things Now i Fix Things To Live
  • brunski
    • Jul 2015
    • 1
    Re: Taskalfa 4500i Dead Display
    Originally posted by Elmo
    Hi All
    thanks in advance
    I have the same issue on KM-3050...the machine is printing normaly but the copy function is not possible. The touch panel is working first 5 sec.#loading program# then go to totally black.
    If someone have the same experience, please help.
    • Elmo
      • Feb 2010
      • 541
      Brunski start your own thread you have a different machine with a different fault
      • Elmo
        • Feb 2010
        • 541
        So far i have replaced parts from a working machine
        control panel complete (checked wiring harness)
        memory
        HDD
        power supply
        but still no display light not even welcome screen
        iam thinking control pba unless anyone has any ideas
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1858
          Do any of the hard switches respond ? Make sure YC24 is connected to the main pwb.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Elmo
            • Feb 2010
            • 541
            tested all previous parts in doner machine all work ok
            replaced main pwb
            machine is now working correctly
            • Has Been
              • Nov 2012
              • 48
              replaced main pwb
              Loose / defective DIMMS
              • Scottb
                • Apr 2013
                • 303
                main board fixed my issue like this
                • madas
                  • Aug 2008
                  • 313
                  Agree with scottb had 2 both times main board.
                  Les
                  • quitech
                    • 82
                    Les
                    Please my good friends, this machine is new in country, we are experiencing this problem and we don't have any place to purchase the main board, so what am asking is that what must be cause of this problem on the main board? If any knows please kindly tell me because I have 12 of this machines both 3500i, 5500i and also the color 4500ci are having the same problem, I need help from you guys because this machines are driving me crazy here
                    • quitech
                      • 82
                      Still on it, please friends is there any solution for this dead display apart from changing the board?
                      • pLatik
                        • 169
                        i have a taskalfa 5500i with the exact same problem. i want to order new main pwb, but i have doubts with the part number of the main.
                        is this the correct part number: 302LH94150?
                        thanks in advance
                        • Tonerkiller
                          • Oct 2012
                          • 665
                          thanks in advance
                          Depends what country you are in. In the USA you need 302LH94141
                          In the 230 volt area you need 302LH94151
                          • pLatik
                            • 169
                            thanks
                            • makeacopy100
                              • Oct 2019
                              • 24
                              Hi All
                              thanks in advance
                              one of my customer had this model taskalfa 5500i and was working fine at the night but when he starts up the machine in the morning the
                              operation panel was dead but we can sound the rotation of machine scanner lamp turn on every thing is working except panel and soon i learn from forums that it is a
                              problem of main board and i dont have any other model like this to be checked with
                              so i am searching for main board across the internet to get this machine ready
                              the machine counter is 150 k and condition is excellent
